Tom/Barb wrote:
Kennedy64 wrote:
DiskDoctr wrote:
Standard?
If so, low gear, slip clutch just a little with wheels straight, then press clutch so all tension is off drivetrain and push the lever.
If not, try same thing in reverse.
Works best if you are on a hill and geared to move up the hill (backing up hill in reverse, etc).
Automatic :(
Jack one front wheel. relieve the strain on the front hubs.
:) Hi, and this is the answer I was going to give you. Once the wheel gets off of the ground, you can see it un-wind.
