Wo_ody
Jun 22, 2014Explorer
4x2 or 4x4?
OK...lets say your camper is a 4500 lb monster like a Lance 1191 or an Arctic Fox 1140 or a heavier Eagle Cap 995. You may get off the pavement to camp but you aren't going to do the Whazoo with it. ...
Wo.ody wrote:
Every post appreciated.
If 4x4, my preference is General Motors Duramax because it has independant front suspension. Hard to believe Ford is stuck in the 1940's with a rigid front axle.
If 2x4 then Ford gets the nod. Per 2015 manufactures literature, the 6.7L F-350 CC dually has a payload rating of 7080 lbs. That's 1532 lbs better than the like GM which is only rated at a payload of 5548 lbs.
Catch up General Motors...I need at least a payload capacity of 6500 lbs!
