Bedlam
Aug 16, 2017Moderator
1. My F250 just fit under a 7' garage door opening with 33" tall tires. An F350 would not due to the taller rear block over the axle.
2. Truck campers can be minimal or extravagant but neither will fit in the garage while on the truck. A pop up will fit in the garage if you use a low-boy dolly.
3. You can easily outfit a low height enclosed trailer with spring over axle lift to be your next toy hauler and still fit it in the garage, but you will not be able to stand up inside. How fancy you make the living accommodations is up to you, but anything will be better than a tent.
44,056 PostsLatest Activity: May 04, 2014
