bikernut's avatar
bikernut
Toy Hauler rear door
my 2007 KZ 41 has a slight problem with the rear door/ramp. It has some how gotten water in it and has rotten out by the water getting in somewhere. I am looking to replace it with a new one but can't seem to find any place that sell replacements. I have tried the KZ website and they aren't answering my request in the customer care contact page. this trailer has only about 7500 miles as it just goes to my campsite in the summer and it is stored inside under cover the rest of the time. can any of you fellow toy haulers help me in getting a replacement or an site where I can order one. thanks
  • Look around you for an independent RV shop. A racing friend of mine does this stuff all the time. Replaces front/rear caps, etc. but he's in Indio, CA
  • Sorry about your situation I can certainly understand. You may be ble to find someone local to do the job for a reasonable cost. Like I said that outside layer can be replaced with marine painted luan wood OR source some aluminum sheeting used on enclosed trailers. Plain white should work. I used to own a KZ New Vision and that was the trailer we did this repair on. Total cost of materials was about $400 but we did not need the outside layer. Cost at the time for a new door was north of $4K.
    Good luck hope you get it resolved.
  • thanks for the replies and suggestions.
    redhooker my outside layer has split from expansion and living in my small home there is no available area to do what you suggest but it would be great also if I wasn't handicapped and incapable to do this but wish I could.
  • These are not tough to rebuild yourself. Especially if the outer fiberglass sheet is in decent shape. Take the door off. Take apart the outside aluminum trim. You will find one or two layers of cheap plywood under the grip surface that overlay an aluminum square tube frame, usually with foam panels between the framing for insulation. Other side of frame will be luan with fiberglass exterior surface.
    Replace rotten wood, the odd size usually means you need to use at least two layers of two pieces of thin luan plywood which comes 4x8. Make your seam vertical (when door is closed) and interlock the two layers by gluing them together with hardwood floor adhesive-full coverage troweled down. Use whatever grip surface you like (rubber diamond plate is nice) and glue that to surface.
    If the fiberglass side is rotten, make the same plywood sandwich and you can paint with marine (Interlux Perfection is very nice) after bondo/mesh over seam. Otherwise just reuse the outside layer.
    Reassemble the outside trim and brackets. It's an easier job that it even sounds.
  • It will probably be a challenge buying a replacement door. Right now all of the part manufacturers are having trouble keeping up with the demand from rv manufacturers. The door manufacturers probably won't sell directly to you and it will likely take a long time for a dealer/repair shop to get one for you.
  • I did some digging around found a couple companies that sell ramp doors Pelland Enterprises and Reaper Custom Fabrication I'm not affiliated or nor do I know anything about them so be cautious.
    I recall some other owners having had issues said a new door ran a couple grand. plus another $700 for shipping.
  • That's a tough one. You might end up having to find someplace local who can use your existing frame to fab something up.
    Finding a local dealer would be a good first step though.
    I've obviously got a different brand than you, but I was able to get my manufacturer to point me to their parts supplier for some body damage. The parts were too expensive to ship, but it was worth it to swing by Elkheart, IN to have them do the work. Not only did they have the parts, but they had a service dept. who could do the job.
  • With supply issues and everything else you may find a tough time getting what you are looking for.
    If you are still in the City/State you listed I'd start by contacting the local KZ dealer in your area;
    Rte. 125 RV & Marine, LLC
    343 Gonic Road
    Rochester, NH, 03839
    Telephone: 603-335-0112
    FAX: 603-335-0531
    Website: www.theroadiscalling.com
    Email: [email protected]
