YamaDooed wrote:
dodge guy wrote:
~DJ~ wrote:
YamaDooed wrote:
If you leave the trans in OD towing over 6000 lbs any distance your trans should be needing rebuilding shortly regardless of your axle ratio. And yes your mpgs will increase also.
A friend of mine lost his tranny not realizing he should tow with OD off.
I've been towing in O/D for years and no problems. Of course the 4.30's help in that department!
Funny how some people give advice on something they have never tried for them selves.
Yes you can drive with it in OD if you have a V10 but the 5.4 with a 3.55 will be shifting in and out of OD and your trans temps will be going thru the roof. And Yes I've tried it many times esp. with fuel over the $4 a gal years. :)
And that is why you go to 4.30's and enjoy the new found power band! The truck will work less and instead of running at 2700 in 3rd you can run 2300 in O/D and let the truck relax! Yes a few hundred rom makes a huge difference!
