mosseater wrote:
Swmpbgy1 wrote:
Greetings........
I just changed the plugs in my 07 Expedition EL.....correct me if I'm wrong, but your 07 should have the one piece spark plug...not the 2 piece that had the tendancy to break. I changed all 8 of mine in about 2 hours....NO breakage......all of mine were the one piece motorcraft plugs. They were the originals as the truck only has 45000 miles on it. They were a bit hard to break loose, but none broke.
Good luck......
Swmpbgy1
I'm getting a lot of semi-dated, conflicting information about exactly when the upgrade changes were made in the head and plug design. My belief is that the changes were made mid to late-year '07 and came to the showroom floor early-mid '08.
Looking at the new plugs, compared to the pictures of the old plugs (since I don't have mine out yet), they look almost identical. They obviously have a parting line between the thread and the tail, so I'm sticking with they're two piece. Everything I'm reading tells me they're somehow "improved". Don't know if, or to what degree that's true. It's also possible that they used a different plug number/type in the Expy's than in the 150's, so that may account for possible disparities, too. I'll give details when I get it finished.
Your best bet is to check with you local Ford dealer Parts counter, give them the manufacture date and the VIN number. This IS the only way to correctly identify any changes which may have happened.
They will be able to give you the correct plug PN which you should be able to cross reference to any of your favorite brands of plugs.
Having just recently gone through a dealer nightmare experience I am going to give you a few tips..
If your layout is like our 2006 F250 you will have a radiator overflow tank mounted above the drives side of the engine. To reach the rear plugs on the driverside, remove the screws holding the tank in place. This allows you to move the tank out of the way and will be able to get to the drivers side plugs much easier.
To get to the passenger side rear plugs, I had to remove the air cleaner box which sits on top of the throttle body ('06 air cleaner box is on top of the TB and has the MAF sensor included on the assembly). I was able to leave the MAF sensor connected and push the air cleaner box aside. This allows access to the passenger rear plugs.
I originally had my dealer change the plugs but that was because they were chasing a different problem and they decided the plugs were worn out and thought new plugs would fix it..
It didn't.
But now after they changed the plugs, I was now getting raw gas fumes in the cab but only when backing up?
So.. I pulled the cops one at a time and discovered #7 plug (remember the dealer changed the plugs..) was HALF TURN LOOSE :E :M
I Tightened the plug and decided to check all an no others were loose..
Lessened the fumes but did not get rid of them.
So.. a few internet searches and I found the answer.. The plugs STILL were not tight enough :E They MUST BE PROPERLY TORQUED OR THEY WILL LEAK.
If you do not have a 3/8" torque wrench, GET ONE AND USE IT. DO NOT GUESS at it by feel, over tightening risks stripping the aluminum heads and under tightening risks raw gas fumes and possible plug ejection.
My understanding on my '06 the plugs at the factory were torqued to 33 FT LBs but when replacing they MUST be torqued to 25 FT LBS.
Your '07 may be the same but I would recommend asking your local Ford dealer truck mechanic for the actual specs for your vehicle.
An additional item, while you have the air filter box off the throttle body, NOW is a good time to CLEAN the throttle body.
This is what put our truck in the shop in the first place. What happens is the crankcase vent is plumbed in right below the throttle body.
This allows heated oil vapors to collect under and around the throttle body plate. This over time and miles creates enough build up that the throttle plate starts sticking.
Starting with the 3V 5.4s Ford switched from the old throttle cable which was direct to your foot pedal to the electronic "drive by wire" system..
With the old direct cable you could detect a sticky throttle plate, drive by wire YOU CAN'T FEEL it sticking and worse yet the computer give you no CEL to tell you..
Instead what happens is if the throttle plate sticks or fails to return to proper closed position the computer commands the system into a fail safe "low" idle. Symptoms is a very slow idle in gear, random stalling or almost stalling when going from drive or reverse to park.
If left long enough you get what we got.. a wrench AND a COMPLETELY DISABLED THROTTLE. This can happen anytime without warning and worse yet while you are driving..
We had this happen while DW was driving home from work during this winter in SUBZERO weather just a few miles from home.. I work an hr away so I was going to be a while before getting to her. I told her to not shut the engine off since I did not know if it would restart.
Once I got home I tossed a chain on and towed it home.
Shut it off in our driveway and restarted.. The wrench light went out and the throttle now worked.
This symptom mystified my local dealer and they threw thousands of dollars in parts and labor at it..
I ended up fixing it by doing a internet search and cleaning the throttle body..
So, get a torque wrench and use it and clean the throttle body and you should be good to go for a while.
A dirty throttle body can ruin your vacation if you are not aware of the symptoms and how to fix. By the way I suspect the dealer would not clean but replace the throttle body.. That part runs about $300 on the internet and I would be willing to bet the dealer would charge better than $600 plus labor..
