Big Katuna wrote:
Bumpyroad wrote:
I made an adapter with a 50 amp male plug and two 30 amp female pigtails. I could choose the side that had the best current.
bumpy
All Amps are created equal. And if one leg has higher voltage then the other, there is something really wrong.
I added a recep on the bed pedestal wired to a 30' extension cord.
My AC comes into the RV under the bed so it was easy to run the new cord into the power bay. When on 30A I plug it into the extra recep on the CGs pedestal so DW has a place to plug in her hair dryer or the electric water boiler.
there have been posts here where people have noted much better current on one side vs. the other. probably due to the campground taking old 30 amp service and "upgrading" it to 50 amp. there might be a much higher load on one side of the service, eg. a lot of additional sites are located on it than the other side. Are you saying that it is impossible for there to be a difference in current/voltage/power,etc. between the two sides? if so, that differs from what has been posted in the past.
bumpy
