MitchF150 wrote:
The Ford brake controller is a FUSE, not a RELAY.. ;) My dealer was kind enough to install all the needed fuses/relays for the tow package that you get in the glove compartment "bag" before I took delivery of it.... :)
I knew this because I opened the hood and looked at the fuse box that's right on top of the rad, right in front of you when you open the hood.. ;)
Sure, if you didn't know to look, who would look?? But, I did know to look, so I was ahead of the curve here.. :)
Knowledge is a good thing.....
Mitch
Controller FUSED
And 'charge circuit'......RELAY
OPs mechanic installed RELAY
