Mr__C
Apr 17, 2021Explorer
50amp EMS w/surge
Will The EMS-PT50X 50amp EMS operate properly if plugged into 30amps? Need to know before I commit...No response from Progressive Ind.
ScottG wrote:dodge guy wrote:ScottG wrote:dodge guy wrote:
If you can get the portable, but wire in a make and female plug in the compartment. This will keep it safe. And for whatever reason will be easy to bypass.
Hardwired version is easy to bypass. Simply flip a switch.
I don’t believe it is on the Hughes Watchdog.
I dont know either. I was assuming this was in reference to the PI Hw50C mentioned earlier. I should have mentioned that model in my post.
