kaydeejay
Sep 28, 2014Explorer
Baja Man wrote:That truck will be fine for most medium sized trailers or fivers out there.
Well, we decided to go truck and trailer instead of a MH. We also decided to purchase the truck and trailer for cash instead of financing. Which brings me to my questions....
The truck has 59K original miles. I have added a trans cooler, gauges, serviced trans, new hoses, belts, plugs, dist cap. rotor, plug wires, new radiator, t-stat, new PS pump, and new smog pump.
I do have a topper that would add storage if I went the TT route (although my decision will not be based on this)
1. With this the new to me truck in sig, would I be better suited with a TT or 5er?
2. Is the truck bed/rear axle strong enough to handle the 5er hitch and hitch weight? I would like to install a hitch that completely hides under bed (when not in use) if I go the 5wer route.
3. I am thinking MAX GVWR of 10,000#. This is within limits based on owner's manual. Is this doable?
Thanks!
If your limit is 10,000# GVWR, then either would work no problem.
Not sure how you will get a hitch that disappears under the bed, unless you go with a gooseneck conversion on the fiver and a turnover ball type hitch.
Be warned that goosenecks put a lot of strain on the fiver frame.
44,056 PostsLatest Activity: Nov 19, 2013
