mdamerell
Sep 28, 2014Explorer
Depending upon the 5er 20% is probably more accurate. Mine runs around 22%. At 10,000 he's probably going to be closer to 2,000# pin. B&W companion hitch might be an option for a clean bed. I went with the Reese Goose Box but that's up to you.
'92 F350 SRW is pretty anemic for towing by today's standards. Would have to weight truck and look at the door post for GVWR. It's probably around 9,900# GVWR and GCWR of 13,500# or 15,000# (with tow package ie rear end). The truck will weight around 7,000# so that's around a 8,000# trailer. The TT will probably be a better option.
These go back to 2002 to give you an idea. In 2005 the numbers took off.Ford Tow Specs
44,056 PostsLatest Activity: Nov 19, 2013
