Yes you can tow another type of 5th wheel with your hitch. Just make sure you have enough bed rail clearance and if you are towing a long distance it needs to be level.
The only one I can think of that would be a problem is a pin used for an auto slider hitch. Then you would have to remove the pin adapter but this is not likely.
