45Ricochet
Feb 15, 2016Explorer
carringb wrote:
Would it even need anything special? Why not just some regular 5th wheel rails cut down to fit? Those run about $100 new. Then most used hitches would probably fit, and the Anderson Ultimate hitch maybe? The Anderson weighs a lot less than anything else.
I can tell you a sheet of plywood is to wide for the wheel wells :M
I believe hitch rails are 4'. I'm sure you would fab something for mounting brackets to the frame, which is pretty small to begin with. Then you have the narrow platform of the truck with the small mirrors.
Just me but a Canyon isn't the correct tool for even the smallest of fifth wheels.
44,027 PostsLatest Activity: Mar 12, 2025
