marininn wrote:
I'm looking at converting a 5th wheel horse trailer to meet my needs.
For diesels, cummins particularly, I am interested to hear mpg numbers from anyone towing these.
I am curious the difference between those horse trailers with flat fronts as opposed to those with curved or pointed fronts, and also ones that sit closer to the bumper than others; and compared to bumper pull trailers of similar size.
(with regular bumper pull camper trailers, which sit farther back and are usually squared and wide, they effectively take all the wind - not tucked closely behind the TV)
A horse trailer 5th wheeler is more narrow and sits much closer to the TV than a camper or camper 5th wheeler, so should gain some efficiency in aerodynamics.
Not interested in knee-jerk opinions, just real info from those that have tried.
Also, the horse trailer is not a huge monstrosity like the camper 5th wheelers. Mpg is very important as I tow a lot, not just a few miles once per year. I have a bumper pull cargo trailer with pointed nose that is only 5 feet wide and the mpg's on it are so much better than my 7 foot wide camper (which is even lower in height).
Also, how does weight affect it? I know air drag is king, but looking at 1,500 lb aluminum trailer empty vs 5-6,000lb steel trailer.
The aero mpg penalty is in the wake. A rounded bullet nose is best. And the sidewalks need a curved radius above and below. (Crosswinds more important than headwinds).
Height is worse than width
Weight is a factor for accel/excel, and for grades. Not so much for steady state.
An RV needs to be livable. It will spend more time every day stationary than moving. RV capacities thus mean more. X number of people over Y number of nights. This is the equation to solve, as mistakes here are costliest.
I get it that ground rent and fuel burn figure largely in people's minds.
So, do you HAVE to have a pickup? It's a lousy tow vehicle just as it's a lousy vehicle to drive. Unstable, too heavy, etc.
An SUV or car mated to a nice used Airstream will beat all the capacities questions, and also beat any pickup truck combo on every score of road performance. Significant risk reduction.
I'm suggesting, widen your idea of what's good.
Don't re invent the wheel.
Practicality got defined when Eisenhower was President. It hasn't changed.
