ShinerBock wrote:
mr61impala wrote:
Let me preface this by saying this is NOT a recommendation.
I recently retired from UPS in the Automotive department, 9 years as a diesel mechanic and the rest of my career managing the shops.
UPS has the largest privately owned fleet of vehicles in the world so cost is a huge factor, I am going to tell you something you will not believe but trust me, it's true.
Around 20010, in an effort to reduce costs and after discussions with the various suppliers, UPS decided to use 10w30 exclusively in all delivery vehicles. Cummins was one of our suppliers who signed off on this decision.
We have been running 10w30 in all 5.9 and 6.7L Cummins, with a 15,000 oil drain interval since that time with no ill effects. Read that again. Most 6.7L engines exceed 500K miles with only water pump, turbo, injector, EGR valve and maybe EGR cooler replacement. I know of one in particular with over 600k miles that still only consumes 2 qts of 10w30 between those 15,000 mile oil changes.
The primary cause of CTD failure is injector failure, stripping the cylinder walls of lubricant. If it starts missing or smoking SHUT IT OFF until the cause is corrected.
Again this is not a recommendation, just interesting results of a huge real world reality.
This is kind of apples and oranges in terms of use. The reason why Cummins signed off on 10w30 for your trucks and many other applications likes it is due your constant stop/starts. Constant stop/starts is not good on many engine parts and adds a lot of wear to cylinder sleeves. Oil recommendations are generally based on applications and a UPS truck application is not the same as most personal use trucks.
For '19-'20 6.7 Cummins with the hydraulic lifters require 10W30 or 5W40 oils and have moved away from 15W40 oils. Some who have ran 15W40 in these trucks have reported rattling or knocking noises.
