blofgren wrote:
otrfun wrote:
LIKE2BUILD wrote:
otrfun wrote:
LIKE2BUILD wrote:
. . . Another point for me is oil change frequency. The manual says to change oil every 15,000 miles or 500 hours and I don't even come close to that mileage in a year. So, I just change my oil once a year and with the 5W40 I'm covered for any temperature range and I don't have to worry about it.
KJ
Our 2016 Ram Cummins OCI is 15,000 mi., 500 hours, or 6 months, whichever comes first. Your profile says you have a 2014 Ram Cummins. Is the OCI different for the 2014's?
You're right, it does say 6 months. However, I'm comfortable with the additive packages in the synthetic oil and use the 1 year time frame. When I changed oil this summer I had only put 5,200 miles on the truck since July of 2019. If I would have changed oil at 6 months it would have been less than 25% used (on a mileage basis).
KJ
I was just curious, thanks. We have an 8y/120k OEM extended warranty, so we'll be sticking with the 6 mo. OCI for a few more years/miles. If we still have the truck after 8/120 we'll probably go to a 12 mo. OCI using 5w-40.
With that being said, gotta wonder which would keep my Cummins runnin' the longest? 15w-40 changed every 6 mo. or 5w-40 changed every 12 mo.? lol! :)
It would probably make no difference as long as you aren't exceeding the mileage specifications. I'm not the least bit worried about the 1 year OCI that I have been using for several years now.
Well, diesels don't destroy oil the same as gas, think gas is a solvent, diesel is an oil.
Our 2001 Ram 2500 CTD ran 15-40 Delo 12 months, 10K miles, had TBN tested to get there comfortably. The last test Blackstone stated plenty of additives left, go for 12,500, I stuck to 10K.
Earlier I added pictures of the tappet gallery when I needed to change the cover gasket at 300K, very clean!
I am seriously considering going by the change indicator, and spend the extra $10 for the TBN, and keep the results if there is an issue.
This six months I put 7,676 miles on the oil, and the change indicator was half way to change.
