ttavasc
Mar 29, 2019Explorer II
JBrady5555 wrote:Lantley wrote:JBrady5555 wrote:
Any insight on adding a secondary gas tank to a gas vehicle?
I know your asking about aux. tanks,However diesels have the advantage of being able to use aux. tanks. Aux. tanks for gasoline are generally illegal and unavailable. Diesels also have a greater fuel range which means you can go farther on a tank of gas. With a diesel you can fuel up at trucks stops when towing, and avoid tiny gas stations and the anxiety that comes with finding a station you can fit into.
Lastly all modern diesels now come with exhaust brakes, that really make a difference when towing in the mountains.
Yea I still would like to have the extra tank even if it has to be manually pumped.
Titan Fuel Tanks makes a small 15-gallon aux transfer tank called the Sidekick which is certified for use with gasoline as well as most other flammable liquids. You use a shaker siphon to transfer the fuel to your main tank. At ~$470 it's not cheap though.
Titan Sidekick Aux Fuel Tank
