1320Fastback
Mar 31, 2019Explorer
Grit dog wrote:Lantley wrote:JBrady5555 wrote:
Any insight on adding a secondary gas tank to a gas vehicle?
I know your asking about aux. tanks,However diesels have the advantage of being able to use aux. tanks. Aux. tanks for gasoline are generally illegal and unavailable. Diesels also have a greater fuel range which means you can go farther on a tank of gas. With a diesel you can fuel up at trucks stops when towing, and avoid tiny gas stations and the anxiety that comes with finding a station you can fit into.
Lastly all modern diesels now come with exhaust brakes, that really make a difference when towing in the mountains.
This is a bit of an untruth. There are plenty of DOT certified transfer tanks and while local regulations may differ, the states I've been in DO allow for it.
A person's comfort hauling a large qty of gas in a transfer type tank may vary, but it is legal and it is done regualrly.
Mfgs make DOT certified transfer tanks for gas. Recreational trailer mfgs make trailers like towyhauler S and motorsports trailers with built in gas tanks and pumps.
I'm not advocating or speaking against it, just stating the facts.
Our SandSport toy hauler has a 20 gallon gas tank with pump built in. Have never used it but would be a option for OP to get into a trailer with one too. We only ride dirtbikes and since they are 2stroke I have to mix anyways so I just use the 5gallon dump cans instead. Have considered putting diesel in it for my truck to extend the range but so far haven't ran into a situation where I'd need it.
