Hybridhunter wrote:
Grit dog wrote:
Wizbangdoodle wrote:
Several pieces of good advice here. I would also suggest, while the cab is off, get studs and do both head gaskets.
I also agree with what was said above, any brand modern diesel is going to have problems. It is their battle with trying to meet government regulations. The 6.4 gets a pretty bad rap, but once they are modded, I'd put one up against any brand for longevity and durabilty. Good luck and safe travels.
"Once they are modded."
Keep defending fomoco Diesel engines. But show me any other high pressure diesel from the last 15 years that needs 5 grand in internal mods just to make it down the road in stock trim under 100kmi besides the 6.0 and 6.4?
Powderchokes blowing head gaskets has exactly zero to do with the epa unless you're blaming them for limiting what Ford was able to use for head bolts and gaskets.
Well it's nice to see how uninformed some are. This and the previous generations of "Ford Diesel" was a NAVISTAR diesel, that Ford bought and paid for to put in their trucks.(And subsequently sued them for and ditched them because of). Just like Dodge (does dodge still exist lol), and Government Motors. And all 3 brands had junk under the hood at various times in the past 10 years. My fleet involvement in the past 15 years tells me that they are all expensive, repair prone, and not reliable. Diesels only shine when compared to the garbage 50's tech that the domestics stuck with well past it's expiry date. The gas engines are thousands cheaper, operate just as long prior to the inevitable multi thousand dollar repair, and for a similar price, you can drop in a new one and still take a cruise with all the moey you saved.
Well correct you are, all of the big Three used others diesels, and two of them re-branded them, Only Ram chose to state what was under the hood.
It is also true the Ford, increased the output of the 6.0 and 6.4 over and above what they were sold by Navistar. This didn't help when they were chipped by the end user.
I would be a bit Leary of now buying a new Ford diesel, as Ford has greater control over the cost of replacement parts for their in house engine.
With Cummins, I have a Ram dealer, after market (not OEM) and Cummins, the interesting part I have found is most of the time the Cummins parts house is the least expensive.
