"To check the glow plugs can I unplug them and measure the resistance to ground? What should it be? "
All I have done to check glow plugs is unplug and use a test light by attaching alligator clip to positive side of battery and touch the spade on the end of the glow plug. If the test light glows it's GOOD. If it does NOT light it's BAD plain and simple.
Glow plugs are a major PITA!!! They don't seem to last very long on the 6.2/6.5 engines.
If you have a fuel filter like pictured below with a primer button hit it before starting and see what happens.
Lift pump may be the problem if the primer method works.
