brooks379ExplorerAug 20, 20156.7 with Ford 6R140 transmissionCan you change the fluid in this tranny DIY like you could the old 5R by draining the pan then disconnecting the cooler lines, starting the truck and drain and fill at the same time to remove the rest...Show More
Related ContentFord Torqshift 6R140 fluid and filter change videoFord TransmissionNewer Ford F53 and 6R140Transmission shudderTransmission cooler options
