taken wrote:
All 4 have a no tuning required kit. Don't forget too, H&S isn't the only one that sells H&S kits. So, just because they are out of stock doesn't mean all their vendors are. I bought my H&S kit from Rudy's and used a coupon code to save another 5 percent and got free shipping too. Coupon code is PSN. If you have an 11-16 truck, I'd get the H&S silicone version from whomever has it in stock. It's a 10 minutes TOPS install.
Rodney is correct. This thread was started to warn others of am impending problem to arise at the most inopportune time. My turbo also had to be replaced over a year after the CAC pipe failure. Same symptoms as was described earlier with the same codes. Rodney was the first that I know of to have this problem followed closely by myself. Thanks to him I had the spare tube with me and swapped it out on the side of the interstate. As long as they make a plastic pipe, I'll replace with one that I know will get me to where I'm going. And I have Rodney to thank for that.
