DirtyOil wrote:
Baw haw ha!! This coming from the self appointed RV.net clean air freak... what a Hypocrite! If your are the so-called expert on emissions, you would know the OEM intake is as good as it gets. As stated earlier, unless your willing to do the whole show... but as you so loudly pointed out in other posts... your just "adding to NOx polluting gang" of "coal burners", Good luck Hypocrite!
Or maybe your just doing this to stir up the hornets nest?
I usually don't post during the weekends because I have better things to do, but I will make an exception since I am the OP. If you would follow my post them you would know I used to work for Cummins. Taking a silencer that is meant to keep the sound of the turbos down is a big difference from deleting your emissions equipment. I suggest you research the difference so you can actually benefit this conversation. I have not said one thing about removing any emissions equipment. Please show me where I have said this to back up your statement.
