DirtyOil wrote:
ShinerBock wrote:
Dirty Oil,
Below is the patent for the device. Please show me where it says anything about emissions or how it affects other people's health.
Silencer for air induction system and high flow articulated coupling
Yup as usual...keep side stepping the issue, you wanted to remove your silencer to get more whistle/noise and to add more power. You have previously posted adding more power increases NOx on a diesel engine(has nothing to do with silencer patents). I'm calling you out on this one. You want to add more power by removing the silencer (as you stated)and by your "interweb expert knowledge" add to the NOx pollution. Again, I will tell you removing the silencer will not increase the power! So go back re-read your original post and maybe edit out the part where you want more power. :R
****, I am on a date tonight with the wife and I have to respond to your ignorant BS. How is that you cannot get that taking a silencer meant to quite the intake is in no way shape or form as taking an emissions divice and illegally making it spew more emission that is lawfully allowed. Honestly, I can see why this forum even allows you to spread your BS since doing so can be counted as an unlawful act act against this forum itself but that is their perogative. Again, LEARN THE DIFFERENCE BETWEEN DELETING AND EMISSIONS DEVICE THAT EFFECTS OTHERS AND DELETING A SILENCER THAT DOES NOT EFFECT ANYONE BUT THE DRIVER.
