the_bear_II
Jul 14, 2014Explorer
Defective Tires
Weight
Tire Pressure
Improper Blocks Under the Tires
Axle Alignment
Curb Strikes
Too High of Speed
These are the major reasons for tire failure.
If your axle alignment was the problem you should have seen problems show up on the tire tread (scuffing or uneven wear)before a blow out.
Go after the tire company and axle manufacturer if you weren't overloaded, speeding or anyone of the other causes above that you had control over.
Weight
Tire Pressure
Axle Alignment
Curb Strikes
Too High of Speed
44,056 PostsLatest Activity: May 04, 2014
