B_O__Plenty
Jul 14, 2014Explorer II
There is no way I would spend $2,000 to replace any axles. There are very few if any RV dealers that can check and adjust all aspects of wheel alignment. Start out by going to heavy duty truck/trailer suspension shop. They will have a rack for alignments. RV dealers won't have this. They can check and adjust all three aspects. Tracking, toe and camber. Next get rid of the junk ST tires you are using and get a set of LT tires or Maxxis ST tires. Nothing else is worth buying.
The alignment check and adjustment should cost around $150-200.00, and with a new set of tires you will still be WAY under $2,000.00 and your problems will be solved.
B.O.
B.O.
44,056 PostsLatest Activity: May 04, 2014
