JIMNLIN
Jul 14, 2014Explorer III
gmw photos wrote:
As an example, a GY Marathon ST in that size has 1760 pounds of capacity. If we assume that all four tires on the ground have an equal loading ( not likely ) then he has 1500 pounds sitting on each tire.
Then add the high speed driving at 65-7 Those tires had to be running hot. Small 14" ST tires aren't the best idea for traveling at those speeds.
Get the bent axle question answered and fixed and use a better type/size tire that can stand up to traveling at those speeds.
44,056 PostsLatest Activity: May 04, 2014
