PawPaw_n_Gram
Aug 06, 2014Explorer
str8nzem wrote:
"cheap Chinese axles"
Be wary of folks who want to blame problems on "cheap Chinese" anything. It is often an easy excuse to get a sale without really finding the problem.
Note - I personally don't like to buy anything not made in the United States if possible. I learned that from the Japanese when I was stationed in Yokosuka. Buying made in my country stuff helps the economy and jobs.
Yes, there are a lot of "cheap _______" products out there. There are also a lot of very good products made in that country used in thousands of trailers every day.
str8nzem wrote:
He also told me that the 'road camber' was gone. The axles should have a slight camber.
Road camber is the tilt of the road, for drainage and curves. It is not a setting on a vehicle.
Tires/ axles should be adjusted so that the tire maintains even contact with the road - no tilt in or out - when loaded.
Unlike the automobile - the trailer hub mount for the wheel does not have any adjustment possibilities. The axle and hub together set the camber and it cannot be changed without bending the axle.
Many trailer axles will have a slight bend. Many do not. If the axle was installed properly, it was adjusted for that individual trailer.
str8nzem wrote:
He mentioned that if the trailer drops off the edge of the roadway the axles could be damaged, he also warned about 'jack knifing' too sharply when backing up.
Also driving over curbs can damage the axle / hub angles
str8nzem wrote:
I dropped the trailer off on Friday morning, Greg called at noon on Monday that my trailer was done. Out the door cost $700.
That's fast work. Be sure to take it back a month later and have him check.
I had a trailer 'alignment' issue. Never had a blowout, because after 1,000 miles, I saw a strange wear problem on the outside edges of the curb side tires - and took it in. Dealer had no idea. Finally took it to a friend who builds race cars, and he pointed me to a company which builds lots of trailers. They were able to help me.
Maintaining tires:
Multiple blowouts always indicates a problem. Either mechanical such as an axle issue, but almost always a usage problem.
Speed - stay under 65 as much as possible. Running 65 usually cuts your MPG by 10-12% from running 60. Another reason to go slower.
Tire Pressures - I highly recommend a TPMS system. I had one tire damaged by a road hazard (piece of steel) on my boat trailer running with a TPMS, and got stopped before the tire blew because of the TPMS warning. Also - make it a firm habit to check tire pressure before heading out for any trip over about 30 miles, or any time the trailer has sat for a week or longer without rolling.
Loading - Trailer gross weight can be within limits, and one tire can be overloaded by as much as 150%. Axles and hitches do not equalize the load on all four trailer tires. Placement of gear inside the trailer - the way the trailer is built - etc - can result in one tire or one axle carrying too much of the load. The only way to be sure is to have the trailer weighed ready for a trip with a per tire scale set or at least by a per axle method.
As mentioned above - the trailer should be level when hooked up and towing. Nose up puts more weight on the back axle, nose down puts more weight on the front axle.
Sudden explosive tire failure on a 150 mile trip is almost always (1) tread separation; or (2) overloading and low pressure and resultant over heating. (Second cause is much more common)
A bad axle issue simply can't cause that much damage that fast to a tire.
Tread Separation - this is a failure of the tire to hold together internally. There is always warning. Mostly the tire will start to bulge slightly. You can find that by running your hands around the tread of the tire. There will also be a fast vibration as the separation creates pockets as the layers separate. Unfortunately, you can't feel the vibration in a trailer in the TV most of the time. That is where a TPMS can save your trailer.
Watch the tire pressures. Watch the tire temps. Touch the tires after a tow - see if one is hotter than the others.
ST trailer tires can last 30,000 miles - if you tow that much in three years, and you take care of the tires.
44,056 PostsLatest Activity: May 04, 2014
