aellarby's avatar
aellarby
6 pin connector wiring
Hi, I hope someone can help me. I just bought a used Jeep and it came with a CURT pin socket where it will connect a cable from the RV to operate the lights on the jeep. I am confused by the various options, especially for the center pin. Some online drawings show the center pin for e-brake, some for auxiliary, some for 12 V power. The case is aluminum it is probably 8 or 9 years old. There are no other marking I can see.
I am attaching a picture.
Many thanks,
Andy
https://www.flickr.com/photos/aellarby/22795571137/in/dateposted-public/
  • George H wrote:
    There are 2 common ways to wire 6 pin connections, as noted in OP. The center pin can be either brake or charge/hot wire. If Jeep is to be a toad, you may not need either option.
    YEP......
    Black wire (12V +) or Blue wire (Brake controller) can be on center pin or top left (11 o'clock) when looking at receptacle on tow vehicle
    The other wires are standard
    Just need to use a meter and check which is 12V +
    Center pin OR 11 O'clock
  • There are 2 common ways to wire 6 pin connections, as noted in OP. The center pin can be either brake or charge/hot wire. If Jeep is to be a toad, you may not need either option.
  • RoyB's avatar
    RoyB
    Explorer III
    Also confer with ETRAILER.com They are everything trailer with components, parts, and drawings. Also alot of how to videos...
    Once you come up with the various part numbers then search AMAZON before you purchase - may be cheaper and faster to get the same items...
    Roy Ken
  • Well it looks like this one:
    Link
    And this is their pinout
    Hopkins
    You can check some of the connections by using a multimeter in resistance mode. Check the ground plug against the vehicle frame for example.
