martinandanne's avatar
Mar 04, 2017
6 Volt Batteries and Solar Charging
I have one of these NOCO 5 Watt Solar Battery maintainers. Assuming I have two 6 volt batteries in series to product 12 volts, am I correct that I would still use a 6 volt controller despite the fact the output from the batteries is 12 volts?
Thinking of switching to 6 volt batteries because going to 2 12-volt batteries may require more space than I have available. But this has led me to a whole lot more questions!
Thanks!
Martin
    If you already have that solar panel you've linked to you don't need anything more - just hook it to the two 6 volt batteries which are connected in series and are in effect a single 12 volt battery. Question is - why bother with such a tiny panel which outputs so little as to be almost meaningless. :h
  • 5 watts is generally too small for two batteries even for storage.
    Need to fully charge first and disconnect everything else.
  • No. Two 6 volts in series is no different electrically than a single 12 V. You want a charger made for a 12 V battery.
