ajriding
Mar 04, 2022Explorer II
My batteries will usually be below 12 by morning. I used to camp / boondock a lot when I used it for work, but use much less now. Batteries are maybe 8 years old, and still going strong. They are GC batts.
The answer is not absolute. There is a balance between using the batteries for your needs, conserving voltage to "save" the batteries, and the fact that you likely will not use them enough to cycle through the life supply of what they can do in a reasonable amount of years.
Most RVers will need 20 years to cycle through half of the available cycles a battery can do. I think 20 years the battery will die of other causes than life cycles first. You have to know what your needs are. A full-time RVer who uses a lot of battery power will need to be judicious with his power use, where a weekender can ignore largely what he does.
44,056 PostsLatest Activity: Mar 02, 2026
