ktmrfs
Mar 04, 2022Explorer III
Boon Docker wrote:ktmrfs wrote:Boon Docker wrote:
This info will help your friend.TBammer wrote:
What type of test is needed to check if the battery might have been abused in the past? Asking for friend.
good info for 12V starting batteries and maybe marine/rv but not really valid for a GC2 battery. One, GC2 seldom if every have a CCA rating to use as a benchmark, Next They have a few very thick plates to much more internal resistance than a starting or marine battery. End result is if you try to load them to the typical load test, results in almost all cases will be "fail" even on brand new GC2. Unless the GC2 mfg gives a recomended load test current.
My experience is that loading a GC2 to between 1/2 and rated rated AH (60-100A on a typical GC2) gives some valid info,
I don't see anywhere that he mentioned a GC2.
nope he doesn't mention ANY info on battery type, so may as well give him info relevant enough to the two common battery types, 6V GC or 12V marine.
and the OP started the discussion stating he is using GC2 batteries.
