pbohart's avatar
pbohart
6 Volt Battery Winter Maintenance Advice?
Hi -
I have had a couple sets of 2 x 6Volt Trojan T125 batteries on my RV over the last decade. I have previously dropped them into my RV then forgotten all about them - including when I drop my RV off on Mount Hood for the winter when the temperatures drop below freezing fairly regularly. Needless to say, I am sure I am not getting full lifespan/value from my purchase.
I just bought a new set which I intend to only use only for regular camping in Spring/Summary/Fall. I will keep the older set for Winter use as I have full hookups where I drop my RV.
Question - Is there a good summary of how to maintain the new set during the Winter? I assume I will be removing them and keeping them on a 6V trickle charger? Any suggestions on a trickle charger that gets the TT forum seal of approval?
Thanks!
  • Awesome advice! Thanks!!
    Is there a 6V battery maintainer that either of you (or others) would recommend?
  • Make sure they're full of water
    Charge them
    Disconnect the cables
    It work fine for me down to -60F.
    Bill
  • Options:
    1. Fully charge the batteries, remove the cables and you will have self discharge of about 4%/month, good for about 6 months.
    2. Charge them at home with a battery maintainer.
    3. Charge them at home about once a month.
