Freep
Aug 30, 2017Explorer
6v or 12v?
All else being equal, which is preferable and why?
2 220 AH 6v batteries
or
2 110 AH 12v batteries
or
adamis wrote:
Additionally though, I would really like to see a fuel cell system to replace the nearly unused generator. A propane powered fuel cell would dramatically increase efficiency
time2roll wrote:Freep wrote:Post the converter model number for best suggestions.
I don't how the battery is charged now when the gen is running or when I'm plugged in. I do remember seeing some device in the basement wired between the gen and something. I'll have to check that out.
pnichols wrote:
It's espeically a shame that motorized RV manufacturers don't install their expensive built-in generators such that they are more quiet and vibration-free to use ... which does not take rocket science engineering or money to do.
Freep wrote:
PianoTuna, thanks for the detailed explanation. This makes me wonder if I would even be able to run a microwave for a few minutes with 2 fully charged Lifeline gpl-31xt 12v batteries.
I really wish the LiFePo batteries were more mature(and cheaper). The reason I settled on AGM is that by the time the AGMs need to be replaced, the LiFePo batteries should be a lot cheaper and easier and also have some built in protection from trying to charge when they are too cold.
pianotuna wrote:
Since the current for twin six volts is going to be double that of twelve volt jars in parallel, there is MORE chance of plates warping from high loads.
F450EC1165 wrote:rjxj wrote:
You cant compare a 12 v gp dual purpose battery to a gc2. As covered in the last go around compare a Trojan SCS225 to two T105
How about two of the Trojan T-1275 Plus at 150 AH each?
