wittmeba wrote:
up2nogood wrote:
Are we talking custom tunes or are we still trying to sell this off the shelf stuff. I have run both , no comparison . Be clear on what you are saying.
Sorry but Im not sure how to answer this question. My tunes were offered by providing the make, model and year to Jody at DP-Tuner via a phone call. I couldnt get to the CPU to give him the number.
He asked me what I wanted then suggested the 40/80/120HP tunes but I dont know if you refer to them as custom or shelf goods. I dont know if any of Jody's stuff is shelf, all custom or some combination. It is a set of tunes that had been proven effective from his Dyno testing. The vehicles when they come from Ford all have the same tunes so vehicle specifics are not a consideration.
I only notice a tweak in the shift points on the 120HP tune and I dont like how it feels - therefore I almost never use it.
Im sure each vehicle would yield a different set of specifications if every vehicle was put on a dyno - but that cost big bucks. Jody talked about $800.00 to setup and dyno a truck like mine.
Personally I dont think hooking my truck to a dyno would yield a much different tune specific for my truck. The trucks are very similar when delivered.
I do think that they guys willing to pay the money for dyno-tunes are also the ones that invest in many other power performance parts and it may make a bigger difference due to the synergies of parts working together.
Jody indicated the guys having the dyno's performed are big time and serious - some in sled pulls and other competitions.
The DP tuner I have is called the F5. ALL the shift points on my truck are different it holds in the gears longer before shifting , and smoother . Torque converter is locked in the lower gears. The tunes I have are plugged into the PCM, and I have a switch mounted on my pillar to change tunes. My truck runs ,and sounds totally different then stock.
