Bedlam
Aug 11, 2016Moderator
I use the slightly higher volume 260 gph with 35' lift pump even though both are rated at 50 psi and physical dimensions are the same:
http://www.harborfreight.com/12-volt-marine-utility-water-pump-94639.html
