In July i went up the Green River Gorge on I-26 in North Carolina it's a 7% Grade. Coming from South Carolina. I was doing 3000 RPM at 40 MPH in the right side truck lane. My truck is a 2002 Dodge Ram...
You didn't say what gear but probably 2nd? Sounds about right. 3,000 is not at all high RPM. It may sound like it only because we are used to cruising around 2000. 5,000 won't hurt an engine for short periods though usually not necessary. 3 or 4,000 RPM's would be better on the motor than "lugging" it up a grade at 1500 in a higher gear.
