Getback
Oct 22, 2013Explorer
7% Grade
In July i went up the Green River Gorge on I-26 in North Carolina it's a 7% Grade. Coming from South Carolina. I was doing 3000 RPM at 40 MPH in the right side truck lane. My truck is a 2002 Dodge Ram...
dodge guy wrote:Hannibal wrote:rhagfo wrote:Getback wrote:
In July i went up the Green River Gorge on I-26 in North Carolina it's a 7% Grade. Coming from South Carolina. I was doing 3000 RPM at 40 MPH in the right side truck lane. My truck is a 2002 Dodge Ram with a 5.9 Liter, V8, 2WD Magnum Gasser engine . The Camper i was pulling was 3,925 lb.( NADA Guides) 1986 Prowler, 25 ft. Does 3000 RPM at 40 MPH sound about right ??
Just a question, what is the Minimum speed on that section of I26? It is my brief that a TV should be able to carry its max GCVWR at the Minimum interstate speed, should that be a requirement?
What do you do on two lane state highways with hills in the 5% to 7% range, just watch the traffic stack up behind you? Sure hope the trailer weighs closer to 6,000# that would help me understand why only 40.
We read here and witness on the roads diesel owners towing 55-62mph on flat interstate quite frequently so traffic stacking up behind isn't a problem on an occasional mountain grade simply because it's a gas engine under the hood. Diesel owners scared to death of a downshift are also holding up traffic on the grades right along with most commercial trucks and rubberneckers.
Agreed. There are many here that don't know how to tow a trailer with a gas engine. They think it is a problem when it winds up to 4500rpm. Automatically they go out and buy a diesel truck. Little do they know it when a diesel winds up to 3000 rpm it is screaming!
