HondavalkExplorer IIMay 14, 20187 pin connector2017 F250, the center pin of the 7 way has no power. I know it usually only activates when in reverse but still no power. Any ideas?
downtheroadExplorerMay 14, 2018There should be a 30 amp fuse located in the number 27 position in the power distribution box under the hood. Check to make sure the fuse is not damaged or missing on your truck
Related Content7 pin plug amperage rating?Problems with 7 Pin Connectorcleaning 7-pin receiver connector on truckHelp - Lance 7 pin connectorWinnebago 7 Pin Connector
