I have a 2004 chevy 2500 hd duramax allison The 7 pin plug does not transfer 12volt to the trailer plug (both the rear or the in box plugs are the same) is their a fusible that has to be added some w...
GM has two different ways of powering up the 12 volts. Stud 1 or two needs to have wire terminated. Look in your owner's manual to see which on your vehicle. Others require the installation of a thrity amp Maxi-fuse in the under the hood fuse panel located on the driver's side wheel well.
