GaetanExplorerAug 05, 20137 pin plugI have a 2004 chevy 2500 hd duramax allison The 7 pin plug does not transfer 12volt to the trailer plug (both the rear or the in box plugs are the same) is their a fusible that has to be added some w...Show More
enblethenNomadAug 05, 2013Yes, on GMs it is possible to drasin trucks battery.I recommend installing a relay energized by ignition switch on position.Wiring diagram
Related Content7 pin plug amperage rating?Loose 7 pin plug7 pin cable7 pin plug questionTT 7 pin plug - Universal?
