I have a 2004 chevy 2500 hd duramax allison The 7 pin plug does not transfer 12volt to the trailer plug (both the rear or the in box plugs are the same) is their a fusible that has to be added some w...
....just be aware that a fuse tap should be used to pull low consumption auto appliances (or, to trigger a relay), not with high-consumption devices (like offroad lamps and such). Read: be careful.
