Gaetan
Aug 05, 2013Explorer
7 pin plug
I have a 2004 chevy 2500 hd duramax allison The 7 pin plug does not transfer 12volt to the trailer plug (both the rear or the in box plugs are the same) is their a fusible that has to be added some w...
This means that if you insert the tap the wrong way round, the device you are powering from the tap won't be protected by the fuse
