Gaetan
Aug 05, 2013Explorer
7 pin plug
I have a 2004 chevy 2500 hd duramax allison The 7 pin plug does not transfer 12volt to the trailer plug (both the rear or the in box plugs are the same) is their a fusible that has to be added some w...
silversand wrote:This means that if you insert the tap the wrong way round, the device you are powering from the tap won't be protected by the fuse
....also a very important point! This Post/thread should be made a sticky....
Silver-
