zogg
May 09, 2013Explorer
Congrats on the tow vehicle....sounds like you did well....higher mileage is not bad if the rest of the vehicle has been taken care, the engine probably has too...
If I recall correctly, the 1500hd is built on the 3/4 ton frame with lighter suspension, which should work ok as long as you are not pulling a 5th wheel, which you are not. So, you get a smoother ride with the towing capability you need....good choice.
We had a 1/2 ton to tow our 5000# trailer and it was fine.....went to a 7500# trailer and pulled it ONE TIME about 60 miles....now I have a 3/4 HD. The extra stability is great....good luck!
