sssooo's avatar
sssooo
7000 generator
I just put in a new Chas set battery in my 2018 Fleetwood bounder ford chassis now my gan won’t start I get a code for actorater?? I maybe it needs reset because of the new battery?
Help scott
  • Battery is tight checked gen worked the carb linkage or gov don’t know for sure jiggled some wires then it started?
    I think it was the linkage I worked
    Thanks all
    Scott
  • The wiring at the batteries, make sure they connected in the correct configuration.
    Then check the governor wiring in box above oil filter.
  • Wiring at the new battery
    Loose or corroded terminal
    Dropped missing wire not connected
