Binfordtexas's avatar
Binfordtexas
7200 pound camper and half ton Dodge?
I need to pull a camper from Houston to South Padre island, about 7 hours. I have a 2013 Dodge ram 1500 4x4. My max axle weight is 3900 a piece. I have a weight distribution hitch and trailer break controller. Camper comes in at 7200 pounds with the minimum of stuff I need to take. I haven't pulled anything this heavy with a half ton. I have pulled heavier with my old diesel but I totalled it not to long ago. Is this asking to much from a half ton?
  • Sounds like I will be fine then. I don't see it going over the rear axle weight I. The way you describe. Thank you for the thorough explanation.
  • It's not the towing capacity that's most important - it's what you have left for payload (tongue weight and the hitch) after the truck is fueled and loaded with occupants in it. Only the scales can tell you that. The TT you describe will put about 750 lbs. of tongue weight on the truck. If the rear axle weight rating minus the scale weight on the rear axle (unhitched) is significantly less than the 750 lbs., you'll be over the axle rating. Being that the route is so flat, I don't think you'll have any problem pulling the trailer. We pulled a TT that weighs about what yours does with a Tahoe and WD hitch. It did OK.
    Rob
  • What is the maximum towing capacity per the door sticker?
