weedlady wrote:
Current owner says it's 31ft. I don't know if that's living space or includes the hitch.
That's all I know until we look at it a little more closely.
Where on the trailer do I look for the "series" name?
thanks for your help,
Martha
Martha
Holiday Rambler produced 5 series of travels in 1973. These where the Holiday Vacationer, Holiday Traveler, Holiday Rambler, Royal Holiday and the Holiday Rambler Park Model. All models where very well built with the Holiday Rambler, Royal and Park Model having Aluminum frame construction and the Traveler had Aluminum frame construction as an option other wise it was a wood frame trailer. The vacationer series was a wood frame but it had the distinction with in the industry of not using what is called stick and tin construction.
What I can tell you about their products is they where very strong and well built. All frames at that time use heavy wall 6" box steel from the hitch to the rear bumper with heavy cross member from front to rear. Solid floor construction with insulated underbelly except on the Vacationer. The side wall use Holidays rambler Alumaframe Construction, which is made up of an aluminum frame that increased strength, eliminated the problem of wood rot and improved drastically the ability to heat and cool the unit. To the aluminum frame was laminated a 1/2" fome-cor insulation, vapor and frost barrier to the inside of the coach and a thermolite barrier to the outside with the aluminum skin mechanically fasten to the frame. In the cavity between the studs would be filled with fiberglass insulation that specially made to not sage over time. It made for a quiet and warm or cool unit to be in. In 1973 all exterior surfaces on all Holiday products had side walls, roof front and rear caps and underbelly of aluminum. The Vacationer had the same but was a wood framed side wall and did not have an underbelly but an exposed frame. Since this is an older unit it likely their have been modification made to it over the years but it should have all the livability features of todays RV.
My spec book for 1973 shows that the 31' holiday Rambler had a weight of 5145lbs from the factory and a hitch weight of 680 lbs. The fresh water system at this time used a pressure tank instead of a demand pump like units being built today. Typical these water tanks where 30 gallons but there was an option for a larger tank of 45 gallons. The black and gray tanks where 30 galloons and the water heater was 8 gallons.
Some of the Rambler and Royal had Mor Ryde Suspension which was a very good system even by todays standards. All Ramblers and Royals series unit had active sway control referred to by Holiday Rambler as ASCS. You might be able to use that method of sway control if you can find the parts of the system that need to inside the tow vehicle. Holiday Rambler stop producing that system in the mid 1980 since the move was at that time way from travel trailer and 5th wheels to motorhomes. If you purchase this unit see if the present owner has the control head and processor for the tow vehicle. If he does and they still work you got the very best active sway control ever produced.
I would think this trailer has had modification made to over the years and I would expect the appliances to ether have been changed or show a pretty good amount of use by now. The advantage you have is the structure of this coach will be strong even after nearly 40 years of use and should give you many year of service into the future with some care. Frankly if the price is right and it looks good I wouldn't hesitate to make the purchase.
I have the complete product information books on Holiday Rambler product of this year and all the technical drawing and many of the build orders at my finger tips if you find you need more information.
Doug
