- mountainkowboyExplorerWe loved our 04
- wolfe10Explorer
William B wrote:
bdpreece wrote:
Great coaches but if you find one you are interested in which has the Roadmaster rr4r chassis make sure it has had the trailing arms replaced. This was a serious safety issue and the original recall replacement parts were as bad also.
But not all Holiday Ramblers. Our Navigator has an S10 chassis with a Detroit Diesel, no trailing arm problem. HR has a large model range.
YES. As he stated it is coaches on the Roadmaster rr4r chassis, whether Monaco, HR or Safari.
Does NOT apply to other chassis. - William_BExplorer
But not all Holiday Ramblers. Our Navigator has an S10 chassis with a Detroit Diesel, no trailing arm problem. HR has a large model range. - down_homeExplorer III've seen a few that were in excellent shape. They did not have some of the features of today's mhs such as slide outs but were better constructed or put together.
There wa two tone light er color over a sort of green model at a RV park in Indiana. He was working on the door. I was pleased with the way the awnings fit and worked, the fit of end caps and it had a solid one piece fiberglass roof, I think, I remember. No checks or fiberglass problems, and the engine compartment was spotless. I guess it was perhaps as much or more pride of ownership upkeep. - bullydogs1Explorer IIThe sad part is that all the people that REV kept on to support the old Monaco/HR products were let go. If you have an older one and call for help you are out of luck.
- William_BExplorer
donn0128 wrote:
In the old days HR was a priemier builder. Later they were bought out a couple of times and quality went in the toilet. The one complaint I had with ours was it felt narrow inside compared to other brands.
I find this comment interesting, considering that while Monaco owned them from somewhere around 2000-2009 they were virtual clones of Monaco. Then Navistar owned them along with all of Monaco. It was after REV bought the remnants of Monaco that the entire line and pecking order was changed. - gboppExplorer
machunt wrote:
while looking for used class A i have come across many Holiday Rambler. i never heard of. any comments.
That's weird. You've been a forum member since 2006 and never heard of Holiday Rambler.
I always thought Fleetwood and HR were the most common RV's.
Enjoy your search, you will find something that fits your needs/wants. - wolfe10Explorer
Yup, here is good discussion of this issue:
https://community.fmca.com/topic/570-serious-problem-some-monaco-holiday-rambler-safari-chassis/?tab=comments#comment-2686 - bdpreeceExplorer IIGreat coaches but if you find one you are interested in which has the Roadmaster rr4r chassis make sure it has had the trailing arms replaced. This was a serious safety issue and the original recall replacement parts were as bad also.
- Holiday Rambler is one of the OLDEST RV makers out there. They have been in business since at least 1972. There were purchased by various conglomerates over the 70's and 80's and Monaco purchased them in the 1990's. So, HR was the Oldsmobile to the Monaco Buick and Cadillac. The HR products were slightly lower cost and did not have the features like the Olds and Buick/Cadillac lines of GM. Anything up to 2008 were very good products. After Monaco went under in 2008, and Monaco was revised and sold by a few new owners, there has not been a good length of time to evaluate the newer products. Doug
38,774 PostsLatest Activity: Mar 01, 2019
