Djsrcy
May 09, 2018Explorer
YC 1 wrote:
Grab a battery jumper cable and find a shiny place on the tow vehicle and then make a shiny place on the TT frame. Connect.
Once you have an absolute known good ground you need to start over.
IF you can open the TT plug while it is plugged into the tow vehicle you can then use a test light to check each pin. Use a 12 volt test light and make sure it shows as brightly on each connection. A voltmeter will lie to you.
Once you are sure the tow vehicle is sending proper signals then go back to any of the tail lights and begin testing there.
Once you have this sorted out you can pull the jumper cable off and if things change you can then address that.
I will buy a test light tomorrow and open the housing on the 7 pin.
I'm not sure what you mean by "go back to the tail lights and begin testing there" test what/how?
thanks
44,066 PostsLatest Activity: Apr 10, 2026
